SaveHTMLToStream and SaveTextToStream
Splinter
Post by Splinter »
I am saving the RVE content to my database file as HTML, and that is working fine.
However, I have another component on the form that displays a sub-set of the 'plain text' from the RVE. What is the correct way to extract the plain text? I tried creating a TextStream and use SaveTextToStream, however it occasionally throws exceptions with the error "Exception class EEncodingError with message 'No mapping for the Unicode character exists in the target multi-byte code page'"
HTMLStream,TextStream:TStringStream;
HTMLStream:=TStringStream.Create('', TEncoding.UTF8);
TextStream:=TStringStream.Create('', TEncoding.UTF8);
rve.SaveHTMLToStream(HTMLStream);
rve.SaveTextToStream('',TextStream,80,false,true); //this line generates exception on some RVE content
myComponent.text := TextStream.DataString.
Re: SaveHTMLToStream and SaveTextToStream
By default, SaveTextToStream saves text using the default Windows code page.
If you created TextStream with TEncoding.UTF8, you need to save UTF-8 as well:
rve.SaveTextToStream('',TextStream,80,false,true, CP_UTF8);
Splinter
Post by Splinter »
Great thanks Sergey, the exception errors have gone away with the addition of CP_UTF8.
On a related note, when I use rve.SaveHTMLToStream(HTMLStream), and save to the database, and then a subsequent rve.LoadHTMLFromStream(HTMLStream, '', CP_UTF8) from the database, an extra line appears at the top of the RVE. So if I type some text on the top line of the RVE, after a save/load it will be one line down, after another save/load it will be two lines down.
I've looked at the HTML code being saved/loaded and an extra <p><br></p> seems to get added on each save. Is there something I can configure to prevent that?
Procedure SaveRecord;
HTMLStream:TStringStream;
HTMLString:String;
HTMLString := (HTMLStream as TStringStream).DataString;
//now save HTMLString to database
Procedure LoadRecord;
HTMLString: String;
HTMLString:=LoadFieldFromMyDatabase;
//showmessage(HTMLString); //after each save and load I can see extra <p><br></p> in <body>
HTMLStream:=TStringStream.Create(HTMLString, TEncoding.UTF8);
rve.Clear;
rve.Format;
rve.LoadHTMLFromStream(HTMLStream, '', CP_UTF8);
rve.Format;
Remove Format after Clear:
rve.Clear;
rve.Format; <------------- REMOVE THIS
rve.Format;
If the editor is completely empty, rve.Format adds one empty text item.
LoadHTMLFromStream does not need document to be formatted, so it's enough to call Format one time, at the end.
Splinter
Post by Splinter »
Doh, I should have thought of trying that. Thanks it worked.
