Display html formatted text?
ramiroelliot
Post by ramiroelliot »
Hi there,
I'd like to make reports based on statistical analyses of some data and looking for component that is able to display rich text with tables. Maybe there is some component that can display html-formatted text?
Could you recommend something?
Re: Display html formatted text?
Our TRichView component can display documents in HTML, RTF and DocX format (for HTML, layout should not be based on floating <div>, they are not supported).
Simple reports can be generated just with TRichView, without add-ons, see viewtopic.php?t=8
If you need more complex report, there is ReportWorkshop add-on: https://www.trichview.com/features/reportworkshop.html
