RTF Question
parad0x
RTF Question
Post by parad0x »
I am using the RichViewEdit Component and I need to be able to Encrypt Rich Text Format so that it keeps the formatting after it has been Decrypted.
I was at first just using the normal TRichEdit, but this is way to limited for what I need to do.
TRichViewEdit is amazing but I am having real frustrating problems trying to get my head around this!
I think to be able to encrypt the text and keep rtf formatting I first should encode it in Base64, I have DIMime units. I have been trying to encode it like this:
MSource,MDest: TMemoryStream;
MSource := TMemoryStream.Create;
MDest := TMemoryStream.Create;
MSource.Position := 0;
MDest.Position := 0;
rve.SaveRTFToStream(MSource,False);
MimeEncodeStream(MSource,MDest);
rve.Clear;
rve.LoadRTFFromStream(MDest);
rve.Format;
MSource.Free;
MDest.Free;
Example: the word 'test' is output like this:
Is this the right way to be doing this?
Could somebody give me some hints on how I can achieve what I am trying to do?
Any hints or a pointer would be very well appreciated, I can encrypt the text no problem it's just knowing how to do it so it keeps the rtf formatting.
Many thanks
Chris
You encrypt RTF file in base64, and you can see base64-encoded text in the output.
To view the original document, you need to decode stream (MimeDecodeStream)
In your example, base64-encoded document is passed to LoadRVFFromStream. It's wrong, but in your case LoadRVFFromStream loads it as a plain text.
parad0x
Post by parad0x »
Hello Sergey,
Thank You for replying. I have just tried an experiment using FileStreams instead of MemoryStreams and RichViewEdit keeps the formatting once it's been Decrypted just fine.
I realise that this is now not related to your component, but I know you are a good programmer! Do you have any suggestions on what I could possibly do to Encrypt/Decrypt using TMemory Streams but also keep the formatting (.rtf) in TRichViewEdit?
Many thanks for your time
Chris
I do not understand why the results are different in TFileStream and TMemoryStream. It should not happen.
parad0x
Post by parad0x »
I made a Unit for the TFileStreams - Encrypt / Decrypt routines:
Encrypt
procedure TCrypto.Encrypt(Stream: TStream; OutFile: TStream);
Var
  Dest : TMemoryStream;
    Stream.Seek(0,soFromBeginning);
    Dest := TMemoryStream.Create(OutFile);
    Cipher.InitStr(Password,TDCP_sha512);  // initialize the cipher with a hash of the passphrase
    Cipher.EncryptStream(Stream,Dest,Stream.Size); // encrypt the contents of the file
    Cipher.Burn;
    Dest.Free;
  except
    Raise CryptoException.CreateFmt('Cannot create file ''%s''.',[OutFile] );
Decrypt
procedure TCrypto.Decrypt(Stream: TStream; InFile: String);
Var
  Source : TFileStream;
    Source := TFileStream.Create(InFile,fmOpenRead);
    Source.Seek(0,soFromBeginning);
    Cipher.DecryptStream(Source,Stream,Source.Size); // encrypt the contents of the file
    Cipher.Burn;
    Source.Free;
  except
    Raise CryptoException.CreateFmt('File ''%s'' not opened.',[InFile] );
I then use it like this:
Encrypt
procedure TForm1.Save1Click(Sender: TObject);
Var
  Stream : TMemoryStream;
if SaveDialog1.Execute then
  rve.SaveRTFToStream(stream,False);
Crypto.Password := '32AFDDDF603850AB04DCD4394B83B44773885E2D9642585F0012AD95A0FC20BEBC650B4067E061F2CE8A4AE4BA224300CEF92D0467B153A9FBB4C94E2BCEC9D4';
  Crypto.Encrypt(Stream,SaveDialog1.FileName);
  Stream.Free;
Decrypt
procedure TForm1.Open1Click(Sender: TObject);
Var
  If OpenDialog1.Execute then
    Begin
Crypto.Decrypt(Stream,OpenDialog1.FileName);
rve.clear;
rve.LoadRTFFromStream(stream);
Stream.Free;
rve.Format;
This all works fine with RichViewEdit and keeps the formatting once it's been Decrypted, all images, Rich Text and everything is restored.
If I try this with TMemoryStreams, I just get rtf code back:
{\rtf1\ansi\ansicpg0\uc1\deff0\deflang0\deflangfe0
I haven't posted all of the RTF code above, just a very small snippet because it's too big. I could post it if you like.
This is really confusing as to why I just can't Decrypt it back and keep (.rtf) formatting using TMemoryStreams.
I need to use TMemoryStreams because I would like to send the Encrypted Text through an email but then at the receiving end it needs to be Copied and Pasted back and then Decrypted. FileStreams are no good because it saves the encrypted content to a File, this would not be good for my program.
Do you know why this is happening? I have been trying to get this to work for a few months now! I am not a Professional Coder and learn as I go along.
Many thanks, and again thank you for your time
Chris
