File Open - Display file names in wrong order
TRichViewConroy
Post by TRichViewConroy »
Using ActionTest.exe.
When I use the normal File Open.
File names - starting with "H" appear at the top!
File names - starting with "A" are lower in the list.
How to fix it?
Re: File Open - Display file names in wrong order
RichViewActions use the standard TOpenDialog component, which uses the system file opening dialog.
TOpenDialog does not have properties allowing to define the file ordering in the dialog. This dialog allows changing order of files in user interface. Normally, Windows remembers user's last choice.
