RVPrint.OnPrintComponent
jgkoehn
Post by jgkoehn »
In version 22.2 of TRichView component RVPrint I am using Delphi12.1:
I am running into TRVBitmap however I can't find RVGraphic or the unit that contains this. (I would rather not upgrade to 22.4 if possible since we normally have to do quite a bit to support each update in our code.)
procedure TfrmPrintPreview.RVPrintPrintComponent(Sender: TCustomRVPrint;
  PrintMe: TControl; var ComponentImage: TRVBitmap);
A note normally when a component is dropped on the form it pulls in the necessary units. This one is not pulling in the needed unit for TRVBitmap in Delphi12.1
Re: RVPrint.OnPrintComponent
I am sorry for the inconvenience.
For VCL, TRVBitmap is defined in RVClasses unit (and = TBitmap)
For FMX, TRVBitmap is defined in fmxRVClasses unit (as a special class)
jgkoehn
Post by jgkoehn »
No worries you are an excellent programmer. I just couldn't solve it. Thank you for explaining
