Problem after upgrading ReportBuilder
beauharlan
Post by beauharlan »
Hello, I use the ppRichView component in some ReportBuilder reports and after upgrading ReportBuilder to the latest version I get this when compiling:
[dcc32 Fatal Error] rbStampaInformativaPrivacy.pas(11): F2051 Unit ppPDFRendererRV was compiled with a different version of ppPDFRendererImage.TppPDFRendererImage
What should I do now? Thanks.
Re: Problem after upgrading ReportBuilder
Run "Install TRichView VCL in Delphi IDE" from Windows Start menu.
It will recompile the TRichView+ReportBuilder integration package.
The advice above works if you upgraded ReportBuilder from another 22.x version. If you upgraded from an older version, re-run TRichView setup.
