[Demo] Indirect drag&drop
Source code:
dropview.zip
(34.38 KiB) Downloaded 1768 times
Compiled (+ support for PNG and GIF)
http://www.trichview.com/support/files/dropview-exe.zip
This demo creates a semitransparent window at the bottom right corner of the screen. The user can drop the dragged data into this window.
The demo opens a viewer window for the dropped data.
The following formats are supported:
- RVF
- RTF
- Hyperlink
- Unicode text
- Text
- Bitmap
- Metafile
- Files (RVF, RTF, text, image)
This demo contains a new component, inherited from TRichView: TRichViewTarget. It accepts the dropped data and loads it in another TRichView or TRichViewEdit (specified in its Receiver property).
[+] History of updates
2008-Dec-9: for compatibility with TRichView 11 and Delphi 2009
2011-Oct-1: for compatibility with TRichView 13.4
2018-Apr-8: for compatibility with TRichView 17.3
Last edited by Sergey Tkachenko on Sat Oct 01, 2011 8:28 am, edited 2 times in total.
Updated.
New event: OnOleDragOver - allows to choose areas where user can drop data
New event: OnOleDropNotAccepted - called after OnOleBeforeDrop if the dropped data are not accepted (for example, dropping files of unknown formats)
Improved: In OnOleBeforeDrop you can disallow dropping (basing on the cursor coordinates)
Stef
Post by Stef »
many many thanks,
I'll hope I find some time late this evening to test it.
cheers,
Stef
Post by Stef »
Yes, it indeed works great, THANKS AGAIN !!
I've send you a demo (hope the attached file will be accepted),
showing the multidrop target I wanted to build.
cheers,
Stef, I uploaded your demo to http://www.trichview.com/support/files/ ... tiDrop.zip
If you want, you can explain here which features it demonstates.
