Sergey,
I store my RVF documents in database BLOB fields. They are loaded into TRichViewEdit components using RVFLoadFromStream followed by Format.
I have had a couple of instances where apparently corrupted RVF's are loaded and when Format is called I get endless "Index Out of Bounds" errors.
Is there any way only one error can be generated and I can abort the loading process? Currently, the application continues to return these errors and it has to be shut down. The try...except clause does not seem to help.
Format On Error
