[Examples] Count of characters and words
Calculating a number of characters
uses CRVData;
function GetCharCount(RVData: TCustomRVData): Integer;
var i,r,c: Integer;
     table: TRVTableItemInfo;
Result := 0;
for i := 0 to RVData.Items.Count-1 do
  if RVData.GetItemStyle(i)>=0 then begin // this is a text item
    inc(Result, RVData.GetItemTextLength(i))
  else if RVData.GetItemStyle(i)=rvsTab then
    inc(Result)
  else if RVData.GetItemStyle(i)=rvsTable then begin
        if table.Cells[r,c]<>nil then
          inc(Result, GetCharCount(table.Cells[r,c].GetRVData));
Call:
r := GetCharCount(RichView.RVData);
This function does not count images, etc.
Updated 2017-02-15 for compatibility with TRichView 16.13. For older versions of TRichView, use ItemLength instead of GetItemTextLength
Last edited by Sergey Tkachenko on Thu Jun 22, 2006 3:33 pm, edited 1 time in total.
Calculating a number of words
You can use a class from RVWordEnum.pas
Create a class
TWordCounter = class(TRVWordEnumerator)
private
    FCounter: Integer;
protected
    function ProcessWord: Boolean; override;
public
   function GetWordCount(rve: TCustomRichViewEdit): Integer;
function TWordCounter.ProcessWord: Boolean;
  inc(FCounter);
  Result := True;
function TWordCounter.GetWordCount(rve: TCustomRichViewEdit): Integer;
  FCounter := 0;
  Run(rve, rvesFromStart);
  Result := FCounter;
(this function treats word written with two different fonts as two words)
Call:
var wcnt: TWordCounter;
wcnt := TWordCounter.Create;
r := wcnt.GetWordCount(RichViewEdit1);
wcnt.Free;
christopher00
Re: [Examples] Count of characters and words
Post by christopher00 »
Sergey Tkachenko wrote:Calculating a number of characters
uses CRVData;
var i,r,c: Integer;
Result := 0;
    inc(Result, RVData.ItemLength(i))
Call:
Will this function count the characters in a TRichViewEdit? The word count function looks like it would.
Yes, it can be used for TRichViewEdit too.
PS: I just modified it to take tab characters into account. Line breaks are still not counted.
beboyle
Calculating Words and Characters
Post by beboyle »
This pair of functions counts the number of words and characters in a TRichViewEdit control. The WordCount function is just a generic routine to return word count from any text. The second is fired when the text changes. It loops through the text items in the RVE and passes each to WordCount and totals up the results.
// Function to provide word count from memo or text field
function WordCount(t: String): LongInt;
  ws: Boolean;
  wc: Integer;
  i: Integer;
  ws := True; // In whitespace
  wc := 0;
  for i := 0 to Length(t) - 1 do
    if t[i] in [' ', #9, #10, #13] then
         ws := True
    else if ws then
        ws := False;
        Inc(wc);
    Result := wc;
// Change in text - count words and characters.
procedure Tform1.RVEChange(Sender: TObject);
  wc, cc: LongInt;
  I: Integer;
  cc := 0;
  wc := 0;
  with RVE do
    for I := 0 to RVData.Items.Count - 1 do
      if RVData.GetItemStyle(I) >= 0 then
        inc (cc, RVData.GetItemTextLength(I));
        inc (wc, WordCount(RVData.GetItemTextA(I)));
  lbCount.Caption := IntToStr(cc) + ' characters, ' + IntToStr(wc) + ' words.';
Calculating a number of words in the selection.
uses RVWordEnum, RVTable, CRVFData;
type
  TSelWordCounter = class(TRVWordEnumerator)
  private
    FCounter: Integer;
    FSelRVData: TCustomRVFormattedData;
    FSelStartItemNo, FSelStartOffs, FSelEndItemNo, FSelEndOffs: Integer;
  protected
  public
function TSelWordCounter.ProcessWord: Boolean;
  Result :=
    not
     (FRVData=FSelRVData) and
     ((FItemNo>FSelEndItemNo) or ((FItemNo=FSelEndItemNo) and (FStartOffs>=FSelEndOffs)))
  if Result then
    inc(FCounter);
function TSelWordCounter.GetWordCount(rve: TCustomRichViewEdit): Integer;
var table: TRVTableItemInfo;
    r, c: Integer;
  Result   := 0;
  FCounter := 0;
  rve := rve.TopLevelEditor;
  if rve.RVData.PartialSelectedItem<>nil then begin
    // multicell selection
    FSelRVData := nil;
    table := rve.RVData.PartialSelectedItem as TRVTableItemInfo;
        if (table.Cells[r,c]<>nil) and table.IsCellSelected(r, c) then
          RunRVData(rve, table.Cells[r,c], 0, table.Cells[r,c].GetOffsBeforeItem(0));
    end
  else begin
    if not rve.SelectionExists then
    // normal selection
    FSelRVData := rve.RVData;
    FSelRVData.GetSelectionBoundsEx(FSelStartItemNo, FSelStartOffs,
      FSelEndItemNo, FSelEndOffs, True);
    RunRVData(rve, rve.RVData, FSelStartItemNo, FSelStartOffs);
  Result := FCounter;
sr1111
Post by sr1111 »
I used this function in the delphi2009 error
[DCC Warning] Unit3.pas(777): W1050 WideChar reduced to byte char in set expressions. Consider using 'CharInSet' function in 'SysUtils' unit.
can you fix this function
ws: Boolean;
wc: Integer;
i: Integer;
wc := 0;
if t in [' ', #9, #10, #13] then
ws := True
else if ws then
ws := False;
Inc(wc);
Result := wc;
chmichael
Post by chmichael »
It is possible to save both counts into the RVF file for performance reasons ?
You can save any additional information in DocProperties
chmichael
Post by chmichael »
Thanks!
Petko
Post by Petko »
It is possible to count lines and paragraphs too, and if yes, do you think that it will be too time consuming when working with large documents (compared to char and word count)?
No, it will be fast.
Count of lines - do you mean lines that depend on word wrapping?
How do you want to calculate the count of paragraphs and lines for tables?
Petko
Post by Petko »
I need something similar to Word's word count. I've made a test and it seems to work like this:
* Lines - they depend on word wrapping and each table cell is counted as a line, if the cell is empty
* Paragraphs - it seems that only items, containing text are counted as paragraphs (empty table cells are not)
You can see my test file here:
http://www.box.net/shared/v9ximbdj0f
Anyway, absolute accuracy is not necessary, speed is priority here. People using a word count function need accuracy in the word and character counts more.
I created functions calculating these values in the most natural way for TRichView. It may be different from Word.
Paragraph count
uses CRVData, RVTable;
function GetParagraphCount(RVData: TCustomRVData): Integer;
var i,r,c: Integer;
  Result := 0;
    if RVData.IsParaStart(i) then
      inc(Result);
    if RVData.GetItem(i) is TRVTableItemInfo then
            inc(Result, GetParagraphCount(table.Cells[r,c].GetRVData));
Use: Count := GetParagraphCount(RichViewEdit1.RVData);
In the show-special-characters mode, you can see pilcrow characters at the end of paragraphs. GetParagraphCount returns the count of these characters. Note that they are displayed in places where MS Word does not display them:
- at the end of table cells
- at the end of tables.
Last edited by Sergey Tkachenko on Thu Mar 11, 2010 7:24 pm, edited 1 time in total.
Line count
uses CRVFData, RVTable, DLines;
function GetLineCount(RVData: TCustomRVFormattedData): Integer;
var i,r,c: Integer;
  Result := 0;
  for i := 0 to RVData.DrawItems.Count-1 do
    if RVData.DrawItems[i].FromNewLine then
      inc(Result);
    if RVData.GetItem(RVData.DrawItems[i].ItemNo) is TRVTableItemInfo then
      table := TRVTableItemInfo(RVData.GetItem(RVData.DrawItems[i].ItemNo));
            inc(Result, GetLineCount(TCustomRVFormattedData(table.Cells[r,c].GetRVData)));
Use: Count := GetLineCount(RichViewEdit1.RVData);
This code uses some undocumented methods.
