Reset
Hans Pieters
Reset
Post by Hans Pieters »
I use exclusively RTF.
It is verry cumbersome that when you have entered e.g. a symbol, and you want to resume typing normal text, that is in the font and size of the document, that the formatting sticks.
E.g. if you want to enter pi x 3 then the 'symbol font' sticks after the pi
I want to have a toolbutton which resets the font to normal text. Is there a way fot this kind of reset, stopping all formatting from that point onward.
[/code]
You can include rvprDoNotAutoSwitch in the Protection option for the symbol font style.
