TRVSpellChecker.Suggest Leaks
standay
Post by standay »
I'm trying to get the list of suggested words from the TRVSpellChecker.Suggest list. When I do this:
ListBox2.Items.Text := Form1.RVSpellChecker1.Suggest(Items[i]).Text;
It works and gives me the list of suggestions, but when I close the app I get a lot of leaks. I'll attach the leak report.
I'm probably using this wrong so if you can tell me how to do this correctly I'd appreciate it.
SRDJournal.exe - 2024-07-07 - 15.24.33 - leak report.txt
(19.78 KiB) Downloaded 1920 times
standay
Re: TRVSpellChecker.Suggest Leaks
Post by standay »
I think I have it now. I'm doing this:
  templist: TStringList;
  //NO TStringList.Create
  templist := Form1.RVSpellChecker1.Suggest(Items[i]);
  ListBox2.Items.Text := templist.Text;
  templist.Free;
and all is well!
