Delphi 11 RXMedia 10.2 installation issue: F2084 URW8036
ISL
Post by ISL »
Hi all,
I'm currenty using RAD Studio 11 Version 28.0.44500.8973 with RXMedia demo v. 9.1, this worked like a charm.
Now I wanted to update to the latest demo 10.2 (test and then buy the bundle).
Unfortunately during the installation process comes up a compiler error:
Error compiling C:\Components\RVMediaVCLTrialDelphi\Trial\11\RVMediaD11.dpk:
Embarcadero Delphi for Win32 compiler version 35.0
Copyright (c) 1983,2022 Embarcadero Technologies, Inc.
RVMediaD11.dpk(134) Schwerwiegend: F2084 Internal Error: URW8036
Is there any chance to get the latest version compiled in RAD 11? I searched the forum but couldn't find a similar error.
Thanks alot for helping.
Re: Delphi 11 RXMedia 10.2 installation issue: F2084 URW8036
The trial was compiled with RAD Studio 11.3 (Version 28.0.47991.2819).
If you have an older version of RAD Studio 11.x, most probably, the installation fails.
The full version has a source code, so it does not have this problem.
Can you upgrade your version of RAD Studio 11?
ISL
Post by ISL »
Thanks for helping, Sergey.
I took this as a chance to upgrade Delphi to the latest release 12.1.
With this version, RXMedia did compile propperly. I also directly placed the order for the full version.
