I would like to insert a text (an RVF stream) at the cursor position. I can insert this using the procedure InsertRVFFromStream(Stream, ItemPos). But how can I convert the current cursor position to an item position?
Thanks.
Insert a text (an RVF stream) at the cursor position
Re: Insert a text (an RVF stream) at the cursor position
Use InsertRVFFromStreamEd, it inserts at the caret position.
