Document from right to left
miwan29
Post by miwan29 »
Hi Sergey
How to make the RichView from right to left with its backgroundBitmap
I can't send images from my PC
Re: Document from right to left
Sorry, I do not understand the question.
How right to left direction is related to a background bitmap?
To set the default text direction from right to left, assign BiDiMode property = rvbdRightToLeft.
miwan29
Post by miwan29 »
I want the RichviewEdit bitmap to be from right to left, not the text or paragraph
in richviewedit bitmap is like this
I want like that
Well, this problem can be separated into 2 tasks:
1. to flip image horizontally
2. to display tiled images starting from the right side, instead of the left side.
As for flipping, I do not think that it should be done at the level of our components, you can flip it yourself (in code, or using a graphic editor).
As for tiled images starting from the right side when TRichView.BiDiMode = rvbdRightToLeft, I'll try to implement it in the next update.
miwan29
Post by miwan29 »
Thanks a lot sergey :D
I'm going to try
miwan29
Post by miwan29 »
good result :shock: :D
