Hi!
I have several questions:
1) I want to insert the page number into the Header or Footer. I did the same as the action
procedure TPageNoSetupForm.btnOkClick(Sender: TObject);
Item: TRVPageNumberItemInfo;
rve: TCustomRichViewEdit;
fScaleRichView.PageProperty.PageNoFromNumber := ePageNo.Value;
rve := fScaleRichView.RVHeader.GetRootEditor;
Item := TRVPageNumberItemInfo.Create(rve.RVData);
Item.NumberType := rvpntDecimal;
rve.InsertItem('', Item);
The number appears but when I double-click on the Header it disappears. What's wrong with my code?
2) Is it possible to show the page number from the second page?
3) Can you provide an example of how to change the alignment of the item: left, center and right?
Thanks!
Insert Item into a Header\Footer
Re: Insert Item into a Header\Footer
1) Before inserting content to the footer, you must activate its editing using StartEditing(srvrveHeader);.
See the explanation here: https://www.trichview.com/forums/viewto ... 203#p39203
2) To insert a page number from the second page, you need to activate the special header for the first page:
fScaleRichView.PageProperty.TitlePage := True.
(or, if you want to do it as an undoable operation, fScaleRichView..SetIntPropertyEd(srvipPPTitlePage, 1)).
Please note that fScaleRichView.StartEditing(srvrveHeader) activates editing heading on the current page.
So, if you call it when the caret is in the first page, it will activate editing of the first page header.
So, if you call it when the caret is in the second or subsequent page, it will activate editing of normal heading (note: it is also possible to have different heading for odd and even pages).
There is an alternative to modifying headers as an editing operations.
Instead, you can modify fScaleRichView.SubDocuments[srvhftNormalHeader], then call fScaleRichView.Format;
This modification must be made when the header is not being edited.
3)
This function returns the index of paragraph style having all properties of the ParaNo-th paragraph style, but the specified alignment.
If such a style does not exist, the function creates it:
Inserting page number and then applying centering:
function GetParaNoWithAlignment(ARVStyle: TRVStyle; ParaNo: Integer;
Alignment: TRVAlignment): Integer;
ParaStyle: TParaInfo;
if ARVStyle.ParaStyles[ParaNo].Alignment = Alignment then
Result := ParaNo;
ParaStyle := TParaInfo.Create(nil);
ParaStyle.Assign(ARVStyle.ParaStyles[ParaNo]);
ParaStyle.Alignment := Alignment;
Result := ARVStyle.FindParaStyle(ParaStyle);
ParaStyle.Free;
fScaleRichView.StartEditing(srvrveHeader);
rve.ApplyParaStyle(GetParaNoWithAlignment(rve.Style, rve.CurParaStyleNo, rvaCenter));
