HunSpell
armagnac
HunSpell
Post by armagnac »
I try to install this functionnality in my project.
I put on the form a RVAHunSpellInterface, a RVHunSpell, a RVAControlPanel and I affect properties.
When I run the program I get an error in
procedure TRVAHunSpellInterface.DoSpellFormLocalize(Sender: TRVHunSpell;
Form: TfrmRVCustomSpell_);
LocalizeSpellForm(Form, FControlPanel);
It seems the FControlPanel is nil, but I don't see where I can affect my RVAControlPanel into the TRVAHunSpellInterface : no property published, no procedure to set the RVAControlPanel as FControlPanel.
Thank you for your help
Re: HunSpell
Do you call RVHunSpell.Check() yourself?
If you assigned RVHunSpell to RVAHunSpellInterface.HunSpell, you should not call RVHunSpell.Check() (because it will attempt to localize a spell-checking dialog and will fail).
Instead, use TrvActionSpellCheck action. This action assigns RVAHunSpellInterface.FControlPanel temporary while checking.
If you still need to call RVHunSpell.Check() yourself, assign RVAHunSpellInterface.HunSpell = nil, perform spelling checking, then restore.
