Markdown Issue with Last Word Styling and Trailing Space
a.mancini
Post by a.mancini »
I've run into a snag while working with Markdown.
It seems there's an issue when the last word of my text is styled (e.g., bold) and ends with a space.
Any tips on resolving this or best practices to follow? Just want to make sure my text formats correctly according to Markdown rules.
Thanks for the help!
Best,
Alessandro Mancini
Re: Markdown Issue with Last Word Styling and Trailing Space
I confirm the problem. It is in saving.
According to Markdown specification (TRichView uses CommonMark version), bold or italic fragment cannot end on a space character.
So in the code
aaa **bbb **
bbb is not bold and asterisks must be displayed (check)
TRichView must modify saving procedure to avoid this problem. It already does it in the middle of paragraphs.
For example, in the text "aaa bbb ccc" bold space after "bbb" is saved as not bold:
aaa **bbb** ccc
instead of incorrect
aaa **bbb **ccc
We need to do the same thing at the end of paragraph.
Quick fix. Open RVMarkdownSave.pas, and change class procedure TRVMarkdownSavingData.FinalizeFormatting to
class procedure TRVMarkdownSavingData.FinalizeFormatting(var CurS: TRVUnicodeString;
  var CurStyle: TFontStyles);
  Formatting: TRVUnicodeString;
  CT: TRVMDCharType;
  if CurStyle <> [] then
    Formatting := '';
    if rvfsBold in CurStyle then
      Formatting := Formatting + '**';
    if rvfsItalic in CurStyle then
      Formatting := Formatting + '*';
    if Formatting <> '' then
      CT := GetLastCharType(CurS);
      if CT <> rvmdctWhitespace then
        CurS := CurS + Formatting
        InsertBeforeTrailingWhitespaces(CurS, Formatting);
    CurStyle := CurStyle - [rvfsBold, rvfsItalic];
Of course, the resulting document will be not exactly the same as the original. But this is a necessary compromise.
a.mancini
Post by a.mancini »
the fix works well, thank you for the support
Fixed in TRichView 22.2
