Leak Using rvActionOpen
standay
Post by standay »
Sergey,
I'm still using rve version 21.7.3. When using an rvActionOpen to open a Word docx file, it opens OK, but I'm getting a leak reported by madexcept in TRVCPInfo (see attached screenshot) when I close the app. This seems to only happen with Word files, but I haven't tried it with every possible file type. Seems to be OK using a text or rvf file. Just docx files are causing the leak whether I open them or drag and drop them in.
I used the ActionTestUni demo to make sure it wasn't something I introduced in the code.
Thanks Sergey
Re: Leak Using rvActionOpen
Can you send me a DocX file where it happens?
standay
Post by standay »
Sergey Tkachenko wrote: Fri Dec 08, 2023 8:28 am Can you send me a DocX file where it happens?
I sent one to the richview gmail account.
standay
Post by standay »
Sergey, Here's a typical docx file I had trouble with:
Hyperthyroidism.docx
(15.98 KiB) Downloaded 7828 times
I confirm the problem.
Quick fix (VCL/LCL version):
Open RVRTFProps.pas
Change the code starting from the line 2764 from
      if (InsertPoint > 0) and item.SameAsPrev and (item.StyleNo >= 0) and
        (CurrentRVData.GetItemStyle(InsertPoint - 1)= item.StyleNo)
       then
to
        (CurrentRVData.GetItemStyle(InsertPoint - 1) = item.StyleNo) and
        (item.Checkpoint = nil) then
standay
Post by standay »
Thanks Sergey, that seems to have fixed it!
The fix is included in TRichView 22.1.1 (currently available only for registered users)
standay
Post by standay »
Thanks Sergey. You probably mean it's in 22.1.1?
Yes, you are right. I corrected it.
