Connect IP Camera Hikvision
I use a Hikvision IP camera, I tried the RVMedia demo program "Media test". I've filled in the host, port, user and password, but it still doesn't work
- cam1.jpg (66.95 KiB) Viewed 248815 times
- cam2.jpg (82.69 KiB) Viewed 248816 times
- cam3.jpg (55.49 KiB) Viewed 248816 times
- cam4.jpg (68.46 KiB) Viewed 248816 times
Re: Connect IP Camera Hikvision
If you know the exact video URL for your camera, it's better to specify it in URL fields. In this case, video will be shown immediately, without searching.
When searching, TRCamera searches:
- for presence of some specific IP camera API (such as Foscam, Panasonic, Axis or compatible);
- in the list of frequently used templates of video URLs.
If your camera is not in them, it will not be found, and the only option is specifying video URL directly.
But there are two important note:
This demo searches for video stream types specified in "video format" combobox. If MJPEG is specified (like on your screenshot), it will search for MJPEG streams. Select "H.264" for searching H.264 streams.
Does the media support Hikvision IP camera?
how to use rtsp in rvmedia?
is there a demo file. because i use ActiveX vlcPlugin Componnet for rtsp
example : rtsp://admin:@[email protected]:554/Streaming/channels/2
There is no special support for Hikvision cameras. However, the template string 'rtsp://IPADDRESS/Streaming/Channels/2' is included in the list of video URLs for searching, so SearchCamera must be able to find your camera (if you choose Video Format = "H.264" in the MediaTest demo).
However, it's simpler to specify your video URL directly.
In the MediaTest demo, clear "Host:Port" fields, and specify rtsp://admin:@[email protected]:554/Streaming/channels/2 in "URL" field.
(username and password can be specified either in "URL" field, or in "User name" and "Password" fields, in must work in both ways)
RTSP and H.264 is supported by RVMedia, but RVMedia requires an external library to display them: either FFmpeg or GStreamer.
64-bit FFmpeg DLLs are included in RVMedia setup, and RVMedia demos are configured to use them.
what if the target platform is WIn 32-bit. I can run it
Newer build of FFmpeg are all 64-bit, you can download them from https://ffmpeg.org/download.html
For 32-bit projects, you can use an old build of FFmpeg, you can download it from https://www.trichview.com/forums/viewtopic.php?p=28524
(if you cannot compile or find FFmpeg yourself for 32-bit, but it's not a trivial task)
When the video is interrupted due to the network or some other reason, I will execute the GetSnapShot function from TRVCamera. How can I know that the data flow to the TRVCamera video is interrupted.
how can i know TRCamera is not getting video data from ip camara
Process OnEndVideoStream event to detect a disconnection.
when I get a snapshot from RvCamera, I get a resolution of 640X360, but when I use http get image it's 1600 X 900. How do I get a higher resolution?
