Version 21.7 Not Working
standay
Post by standay »
I tried installing the latest version 21.7. It seems to go through the install correctly, but when I open delphi 10.3, I'm getting multiple errors like these:
I tried uninstalling it and reinstallingit and no change. I reinstalled 21.5 which is the version I've been using and it installed and ran fine.
Re: Version 21.7 Not Working
Most probably the error happens because you upgraded TRichView but did not upgrade ScaleRichView.
Upgrade all our components, and these errors must disappear.
standay
Post by standay »
Yep, absolutely right. I had the scale rv trial still installed. Took that out and 21.7 worked OK.
Thanks!
