Onenote print
sigbert
Onenote print
Post by sigbert »
I accidentally specified Onenote as the printer here. The result is an Access Violation, somewhere in the RV sources. Of course, nobody uses that. But the AV is unattractive. Any ideas?
Prevent printing to Onenote:
RV_GetPrinterDC.....
if LowerCase( Printer.Printers[Printer.PrinterIndex])=LowerCase('OneNote') then
  raise Exception.Create('Can''t print to OneNote');
  Exit;
Re: Onenote print
Can you tell me which line of TRichView code raises an exception?
I have "OneNote for Windows 10" and "OneNote (Desktop)" printers, both seems to be ok.
Printing to OneNote should not be different from printing to any other printer.
sigbert
Re: Onenote print
Post by sigbert »
I only have “Onnote” as the driver.
It appears that adding any line of code to RV_GetPrinterDC resolves the error.
Printer.Printers[Printer.PrinterIndex];
or everything
encapsulate in
 Try except
A
Sleep(X)
does nothing.
The error will probably lie somewhere else.
I don't think we'll waste any more time on this.
No errors are thrown with my report builder.
sigbert
Re: Onenote print
Post by sigbert »
Apparently a bit of CPU work helps for me
 Dummy :=''; while Length(Dummy)<10 do  Dummy:=Dummy+' ';
Re: Onenote print
But it's sweeping the problem under the rug.
If an exception happens in the same line of code every time, knowing this line may help to solve the problem.
sigbert
Re: Onenote print
Post by sigbert »
Yes, you are right, but it pops immediately after exiting RV_GetPrinterDC.
function TPrintableRVData.InitPrinterCanvas: TCanvas;
var HDC: THandle;
   HDC := RV_GetPrinterDC;
//error here
   if HDC=0 then
RV_GetPrinterDC
end. //no error yet
Re: Onenote print
Can you debug RV_GetPrinterDC?
After calling Printer.GetPrinter, what values are written to ADevice, ADriver, APort?
(only characters before the first #0 matter).
For example, for me:
ADevice = 'OneNote (Desktop)'
ADriver = ''
APort = 'nul:'
sigbert
Re: Onenote print
Post by sigbert »
Found!
My Richview to old ? Sorry.
Microsoft.Office.OneNote_16001.12026.20112.0_x64__8wekyb3d8bbwe_microsoft.onenoteim_S-1-5-21-3759952986-2211634303-2982840940-1001
function RV_GetPrinterDC: HDC;
var ADevice, ADriver, APort:array[0..1023] of Char;//old array[0..79] of Char;
Re: Onenote print
Wow, I suspected it, but I never thought that such long names are possible.
I'll increase array sizes in the next update.
sigbert
Re: Onenote print
Post by sigbert »
probably after the next windows update:
array[0..infinite]
Re: Onenote print
I increased the buffer limit ro 1024 characters in TRichView 21.7.1.
The problem is in using VCL's TPrinter.GetPrinter method that copies strings to PChar buffers
I posted a request to Embarcadero for implementation of a safe version of this method, with String instead of PChar, https://quality.embarcadero.com/browse/RSP-42404
