Insert in a single file the contents of varios richviewedits
How can i assign the contents of varios richviewedits into a single file ?
As a single document or as several documents?
If as a single document, you need to add documents from all these richviewedits in one richview and save it.
If you need to save them as separate documents, you need to do it yourself (or use some database)
procedure AddDoc(source, dest: TCustomRichView);
var Stream: TMemoryStream;
source.SaveRVFToStream(Stream, False);
Stream.Position := 0;
dest.InsertRVFFromStream(Stream, dest.ItemCount);
Stream.Free;
RichView1.Clear;
RichView1.DeleteUnusedStyles(True, True, True);
AddDoc(SourceRV1, RichView1);
AddDoc(SourceRV2, RichView1);
AddDoc(SourceRV3, RichView1);
RichView1.SaveRVF('All.rvf')
