CaretMove bug??
yoon jin suk
CaretMove bug??
Post by yoon jin suk »
I uses RichViewEdit v1.9.22 and RVRuler.
and I uses Delphi 7.
I uses OnCaretMove event..
SomeTimes 'List Index Out of Bounds Exception' is accured.
The source which is in OnCaretMove event Function is only..
if RichViewEdit1.CurItemNo = -1 then
I guess .. RichViewEdit1.CurItemNo might problem.
Is it CaretMove's bug?
How can I use CaretMove event with no Exception raise..
shmp
Post by shmp »
Try updating the TRuler first?
Yes, upgrade to the latest TRichView (1.9.24) and the latest RichViewActions (http://www.trichview.com/resources/acti ... tionsb.zip)
I hope the problem will be fixed.
yoon jin suk
Thank you~
I solved it~ Thank you~
The cause was version problem. thank you~
