RichView 2 DB
Aida
RichView 2 DB
Post by Aida »
How can I save the whole text wich is written in a richViewEdit with it'a format into database.
Thanks in advance.
function SaveRVFToField(rv: TCustomRichView; tbl: TDataSet;
  const FieldName: String): Boolean;
var Stream: TStream;
  Stream := tbl.CreateBlobStream(tbl.FieldByName(FieldName), bmWrite);
    Result := rv.SaveRVFToStream(Stream, False);
    Stream.Free;
Example:
table.Edit;
SaveRVFToField(RichView1, Table1, 'Document');
table.Post;
See also the demo in
Demos\Delphi\DB Demo\2 RichViewEdit\
Last edited by Sergey Tkachenko on Tue Sep 05, 2006 5:05 pm, edited 1 time in total.
Aida
Post by Aida »
Thanks Sergey, it works well as I want.
Also I want to move RTF From DB 2 RichViewEdit 'The opposite operation', if u please.
  Stream := tbl.CreateBlobStream(tbl.FieldByName(FieldName), bmRead);
    Result := rv.LoadRVFFromStream(Stream);
    rv.Format;
    Stream.Free;
The code above assumes that documents in DB are in RVF (RichView Format), this is a default saving format for TDBRichViewEdit.
If you are not sure about format, use LoadFromStream(Stream, rvynaNo) instead of LoadRVFFromStream
Aida
Post by Aida »
The format I want is RTF , and this will not work if I use ADOTable...
The code you have supplied me with works with BDE Tables NOT ADOTables
You can change to SaveRTFToStream and LoadRTFToStream.
TADOTable is derived from TDataSet, like TTable.
The only used method of table is CreateBlobStream, it is introduced in TDataSet (and, according to the help file, implemented in TCustomADODataSet, ancestor of TADOTable)
If this method does not work, the chosen field type is incorrect for TRichView. It must be of BLOB type.
