I have a problem with DBRichViewEdit when using a SQL text field or varchar 'or any' that is
when I make the table active it shows an error message 'Invalid class typecast'
Thanks in advance.
DBRichViewEdit with SQL.Text or Varchar Field
I tried the following:
1. change the type of the table to BLOB.
2. Connect the DBRichview with this field.
3. Test the example .
The problem I got is :
when I first connected DBRichview with this blob field , it worked well . BUT after insertion the field type 'ClassName' changed into varbyte...
Would u please tell me how can I Keep it BLOB.
Thanks.
Thanks.
