RVReportDxMemDataProvider - Memory leak
ReportWorkshop support and discussion (TRichView reporting add-on)
Ceprotec
Post by Ceprotec »
Attached is the madExcept leak report (I changed the default extension "mbr" to "txt").
memory_leak.txt
(102.38 KiB) Downloaded 9709 times
Re: RVReportDxMemDataProvider - Memory leak
I confirm the bug.
Quick fix: open RVReportMemDataProvider.pas, delete lines 94..97:
  Result := TRVReportDBQueryProcessor.Create(DataSet,
    LDestroyAfterUse, LUseRecordCount);
  TRVReportDBQueryProcessor(Result).FSupportsRecordCountByDefault :=
    SupportsRecordCountByDefault;
This fix will be included in the next update.
Ceprotec
Post by Ceprotec »
Solved, thank you.
