Script Variables
ReportWorkshop support and discussion (TRichView reporting add-on)
Ceprotec
Script Variables
Post by Ceprotec »
When I assign an empty value to a variable, when using it right away, it is not recognized (rvrgeVariableUnknown)
set %liv_fol_ins = ""
set %liv_fol_ins = %liv_fol_ins+"text"
Re: Script Variables
I confirm the problem. It happens when this script is executed twice.
Quick fix.
Open RVReportGenerator.pas
Change the line 4373 from
SL.Values[VarName] := VarToUStr(Val)
to
SetValueWithoutDeletion(SL, VarName, VarToUStr(Val))
Then define the procedure SetValueWithoutDeletion as
procedure SetValueWithoutDeletion(SL: TStringList; const Name, Value: TRVUnicodeString);
  I: Integer;
  I := SL.IndexOfName(Name);
  if I < 0 then
    SL.Add(Name + '=' + Value)
    SL.Strings[I] := Name + '=' + Value;
Ceprotec
Post by Ceprotec »
Partially resolved. It still happens with the first record in the first generation of the report (in the second generation it works)
set %teste = ""
set %teste = Upper(%teste) + Upper("1")
When do you call this script?
The variable is not assigned before the first call of "set".
You can initialize it in the script that is called before report generation:
RVReportSetScriptAsString(rv, rvrsOnStart, 'set %teste = ""', True);
Or you can initialize RVReportGenerator's variables before executing:
RVReportGenerator.Variables.Clear;
RVReportGenerator.Variables.Add('teste=');
Ceprotec
Post by Ceprotec »
Sergey Tkachenko wrote: Fri May 12, 2023 1:18 pm When do you call this script?
Initializing the variable (rvrsOnStart or RVReportGenerator.Variables.Add) resolved the issue.
I add scripts in TRVReportTableItemInfo.RowGenerationRules.
PS: If the script is added to rvrsBeforeRecord, it is not necessary to initialize the variable. If I add to rvrsAfterRecord, I need to initialize the variable as you demonstrated.
Ceprotec wrote: Fri May 12, 2023 2:08 pm PS: If the script is added to rvrsBeforeRecord, it is not necessary to initialize the variable. If I add to rvrsAfterRecord, I need to initialize the variable as you demonstrated.
As expected. If a variable is defined in the script, and If the script is called after processing a record, this variable is not defined when processing the first record.
Ceprotec
Post by Ceprotec »
When the report (report properties) does not have a data query assigned, the events are not called.
I think that at least the Script_OnStart and Script_OnEnd events should be triggered. Is it possible to make this change?
I agree.
I made this change in my version.
Let me know if you need this change urgently.
Ceprotec
Post by Ceprotec »
Sergey Tkachenko wrote: Thu May 18, 2023 8:42 am Let me know if you need this change urgently.
No.
When do you plan to release an update?
There used to be private forums for subscribers, if it still exists, can you subscribe me to them?
In the beginning of June.
I want to add a couple of features (multi-format Linux clipboard with FMXLinux 1.74, and starting value for markdown lists), but I am implementing it in background, because currently I am focusing on RVMedia.
Finally, it is implemented, in ReportWorkshop v5.2.2. Script_OnStart and Script_OnEnd are executed even if the root DataQuery is empty.
