Localization problem
cychia
Post by cychia »
I have check out the RV demo for Localization.
Tested the following function:
RVA_LocalizeForm();
but it only change the rvaction caption. How can i change the all component in the rv form caption? like the Table Properties dialog etc which created by rv action.
RVA_LocalizeForm() applies the selected language to all richviewactions on the given form/datamodule (it changes their captions and hints)
RVA_LocalizeForm() does not change language, language should be changed before calling RVA_LocalizeForm().
The language is changed:
1) by assigning value to the Language property of RVAControlPanel (there must be only one TRVAControlPanel component in the application). A list of available values for this property is returned by RVA_FillLanguageList() (defined in RVALocalize unit).
or
2) RVA_ChooseLanguage allows to select language in dialog
