Windows Textscaling (100%/125%)
bsteiner
Post by bsteiner »
we use TRichView Version 20.3 and ReportBuilder.
If a report contains richtext and a PDF file is saved with it, the result looks like the pictures.
Can you help us with this problem?
Sincerely
Benjamin Steiner
Re: Windows Textscaling (100%/125%)
Is your application DPI-aware?
As far as I remember, these problems happen in non-DPI-aware applications.
I spent a lot of time trying to solve them, but failed.
But, as far as I remember, it is even worse for ReportBuilder standard rich text object.
As far as I remember, this problem does not happen in DPI-aware application, and UI of new versions of ReportBuilder must support high-DPI display modes.
What's the value in you project options, page Application | Manifest:
1) Manifest File (should be "Auto Generate")
2) DPI Awareness (should be "Per Monitor v2")
bsteiner
Post by bsteiner »
thank you very much this seems to fix the problem.
Sincerely
