Document Attachments and RVAttachedFile
standay
Post by standay »
I've been working on a way to embed attachments in my rvf files. I found a post on RVAttachedFile. I tried that but can't get it to work, it looks like the post is pretty old now. Did RVAttachedFile ever get updated?
What I'm doing now is using TNetEncoding base64. Here's what I'm using:
//https://stackoverflow.com/questions/5795263/binary-to-base64-delphi
function TryEncodeFile(const AFileName: string; out ABase64string: string): Boolean;
  MemStream: TMemoryStream;
  MemStream := TMemoryStream.Create;
    MemStream.LoadFromFile(AFileName);
    ABase64string :=
      TNetEncoding.Base64.EncodeBytesToString(MemStream.Memory, MemStream.Size);
    Result := True;
    MemStream.Free;
//https://stackoverflow.com/questions/6445089/how-to-convert-tbytes-to-binary-file-using-memorystream
procedure SaveBytesToFile(const Data: TBytes; const FileName: string);
  Stream: TFileStream;
  Stream := TFileStream.Create(FileName, fmCreate);
    if Data <> nil then
      Stream.WriteBuffer(Data[0], Length(Data));
    Stream.Free;
I insert an attachment like this:
    if TryEncodeFile( OpenDialog1.FileName, MimeFile ) then
      rve.DocProperties.Values[ 'att:' + ExtractFileName(OpenDialog1.FileName) ] := MimeFile;
      rve.ApplyTextStyle(4); //jump
      rve.InsertTextW(ExtractFileName(OpenDialog1.FileName));
      rve.ApplyTextStyle(0); //normal
      rve.InsertTextW(' '); //add trailing space
And in my rveJump, I use this to open the attachment:
    if rve.DocProperties.Values['att:' + rve.GetCurrentItemTextW] <> '' then
      Data := TNetEncoding.Base64.DecodeStringToBytes(rve.DocProperties.Values['att:' + rve.GetCurrentItemTextW]);
      if Data = nil then exit;
      SaveBytesToFile(Data,ExtractFilePath(Application.ExeName) + rve.GetCurrentItemTextW );
      if FileExists(ExtractFilePath(Application.ExeName) + rve.GetCurrentItemTextW) then
        ShellExecute(0,PChar('open'),
          PChar(ExtractFilePath(Application.ExeName) + rve.GetCurrentItemTextW), nil, nil, SW_NORMAL );
This works great IF the file being "attached" is < 75MB. If it's larger the TNetEncoding.Base64 calls fail with an out of memory error.
Have you ever gotten this working? And if so, do you have some code you can post?
Thanks Sergey
Re: Document Attachments and RVAttachedFile
There is one more way for saving additional information in RVF file: DocObjects property.
This is a collection of objects inherited from TRVDocObject class. All these objects, including all their published properties, can be stored in RVF.
When using DocObjects, you can save binary data as they are, without encoding as text.
I attached a unit that implements TRVFileDocObject, an object that can store file content and a file name.
To use it, make sure that rvoSaveDocObjects and rvoLoadDocObjects are included in RichViewEdit1.RVFOptions.
Example of adding a file:
  FO: TRVFileDocObject;
  FO := TRVFileDocObject.Create(RichViewEdit1.DocObjects);
  FO.LoadFromFile('d:\test\1.bmp');
  FO.FileName := '1.bmp';
RVFileDocObject.pas
(2.12 KiB) Downloaded 1656 times
standay
Post by standay »
Yes, this works as well as the base64 method but without the size limits. I was able to store and retrieve a 131MB audio project with no problems.
I don't plan to store much of anything as "attachments," but if I do need to do that it's good to know I can do it without issues.
Thanks Sergey
