How to Select lines ?
l0f
Post by l0f »
Examples:
aaaaaaaaa
bbbbbbbbb
cccccccccc
ddddddddd
eeeeeeeee
I'll select the Data between ********* and ********* ,
bbbbbbbbb
cccccccccc
ddddddddd
What should I do .
if you understand chinese please read the below text :
(我想选择*********和*********之间的数据,应该怎么办?)
thank you !
Do you want to select lines in program code?
Do you mean lines on screen or paragraphs? Lines depend on word wrapping, text may be wrapped differently if user resizes window. Paragraphs are added when user presses Enter key, they do not depend on window width and word wrapping.
l0f
Post by l0f »
to [ergey Tkachenko]:t
hank you .
if the data like this:
aaaaaaaaa *bbbbbbbbb cccccccccc ddddddddd *eeeeeeeee
i'll get data between * and *
(Maybe include table ,Paragraphs...)
what should I do?
i use delphi .
please show me code .
Do you need to copy all content of TRichView between '*' characters?
I.e. the code should search for the first '*', remember it location, search for the next '*', and copy fragment between them.
