Is there a "built-in" or simple way to generate a small thumbnail image of a given rvf file? I've searched and so far have not discovered anything for this. I'd like to be able to generate a small thumbnail that I could insert into the rve I'm using.
Thanks Sergey
Doc Thumbnail
Re: Doc Thumbnail
Sorry for the delay.
You can use TRVReportHelper to draw a document into bitmap of the specified size.
Like this:
Probably, it makes sense to create this bitmap larger than the thumbnail size, and stretch-draw it to thumbnail.
You can use RVThumbnailMaker object from RVThumbMaker unit.
Like this:
function MakeBitmap(const FileName: String; Width, Height: Integer): TBitmap;
var rvh: TRVReportHelper;
Stream: TFileStream;
bmp : TBitmap;
Result := nil;
bmp := nil;
bmp := TBitmap.Create;
bmp.Width := Width;
bmp.Height := Height;
rvh := TRVReportHelper.Create(nil);
rvh.RichView.Style := TRVStyle.Create(rvh);
rvh.RichView.RVFTextStylesReadMode := rvf_sInsertMerge;
rvh.RichView.RVFParaStylesReadMode := rvf_sInsertMerge;
rvh.RichView.RVFOptions := rvh.RichView.RVFOptions + [rvfoIgnoreUnknownPicFmt,
rvfoIgnoreUnknownCtrls, rvfoConvUnknownStylesToZero,
rvfoConvLargeImageIdxToZero, rvfoLoadBack, rvfoLoadLayout];
Stream := TFileStream.Create(FileName, fmOpenRead);
rvh.RichView.LoadRVFFromStream(Stream)
Stream.Free;
rvh.Init(bmp.Canvas, Width);
rvh.FormatNextPage(Height);
if rvh.Finished and (rvh.GetLastPageHeight<Height) then
// remove this code if you need a bitmap exactly Width x Height
Height := rvh.GetLastPageHeight;
rvh.DrawPage(1, bmp.Canvas, True, Height);
rvh.Free;
Result := bmp;
except
bmp.Free;
function MakeThumbnail(const FileName: String; Width, Height: Integer): TBitmap;
bmp: TBitmap;
const
Ratio = 3;
Result := nil;
bmp := MakeBitmap('c:\Docs\test.rvf', Width * Ratio, Height * Ratio);
if bmp = nil then
Result := RVThumbnailMaker.MakeThumbnail(bmp, bmp.Width div Ratio, bmp.Height div Ratio);
bmp.Free;
Re: Doc Thumbnail
Thanks Sergey, I'll give this a try. No problem on the delay, not an urgent thing.
Re: Doc Thumbnail
Sergey,
I finally had a chance to implement this and it works. I use some rvf files as "covers" (i.e., a little text with a big central image) in my app. Creating thumbnails of the files in my covers folder lets me select files visually in the open dialog which is much better than just seeing filenames.
Any chance of a system DLL that would let Windows explorer show previews of rvf files in all explorer windows?
Thanks again Sergey!
