Hi there,
I'm sure there's a way to deal with this, but I just can't find an answer...
How do I turn off paragraphing and only have RichViewEdit insert a line break when Enter is hit. Basically, make the editor do a Shift-Enter when Enter is hit. The issue is, when I export to HTML, the outputted document appears with large double spaces because P tags are being inserted throughout it.
Regards,
Andrew
Handling Paragraphs
Re: Handling Paragraphs
Sorry, there is no option to add line breaks instead of paragraph breaks on Enter.
But there is an option to save <div> instead of <p> for paragraph. Browsers do not add spacing to <div> by default.
As I understand, you save a simplified version of HTML (which uses formatting tags instead of CSS), otherwise TRichView would save paragraph spacing to HTML.
In this case, assign
RichViewSavePInHTML is a global variable defined in CRVData unit.
RichViewSavePInHTML = False;
Fantastic! That did the trick. Thanks so much Sergey.
