Custom Actions
wvd_vegt
Custom Actions
Post by wvd_vegt »
Is there an action available that allows you to assign an event handler that gets the TRichViewEdit instance passed? If not, what should i subclass to create such action?
I'm looking for buttons that will nicely enable and disable when a TRichViewEdit is active and peform some custom operations like updating the preview inside the webbrowser.
Any action can do that.
You need to override methods:
function TrvAction.HandlesTarget(Target: TObject): Boolean;
  Result := Target is TCustomRichViewEdit;
// updating actions properties
procedure TrvAction.UpdateTarget(Target: TObject);
  // Target is a TCustomRichViewEdit
  // but it may be cell inplace editor
  // To get the real editor, use
  // TCustomRichViewEdit(Target).RootEditor;
  // Here you can update the action's properties
  // such as Enabled or Checked, depending
  // on the RichViewEdit state and other
  // circumstances
// executing
procedure TrvAction.ExecuteTarget(Target: TObject);
  // Execute the operation
For examples, see RichViewActions, RichViewActions.pas.
Guest
Requirments
Post by Guest »
What do i need to get this to work? :wink:
wvd_vegt
Post by wvd_vegt »
I PM'ed a simple version to Sergey Tkachenko to see wether he likes it and want to add it to the RichView Actions.
