WebCam example Delphi 10.2
Graw
Post by Graw »
when I try to use the webcam example I get an error when I press camera on.
It depends on the procedure btnSnapShozClick.
The z.Free is the reason for the error.
But when I remove this line the RAM is getting higher and higher with each Snapshot.
How can I solve this issue?
Thanks.
procedure TfrmMain.btnSnapShotClick(Sender: TObject);
  Img: TBitmap;
  z : TRVImageWrapper;
  if Globalz then
    Exit;
  globalz := True;
    image1.Canvas.Lock;
    z := RVCamera1.GetSnapShot;
    Img := z.Bitmap.GetBitmap;
    image1.Picture.Assign(img);
    FreeAndNil(Img);
    z.Free;
    image1.Canvas.Unlock;
  Globalz := False;
Re: WebCam example Delphi 10.2
Remove the line
FreeAndNil(Img);
Graw
Post by Graw »
Great,
thanks a lot.
