How to specify default font when printing HTML with TRichView v21.0
svinson
Post by svinson »
I have updated to the latest TRichView v21.0. I have two components dropped into my Delphi form:
[list]RichView1
RVStyle1[/list]
I then set RichView1.Style to RVStyle1
I then have the following function to display HTML:
[code]procedure TMyForm.renderHtml( const htmlMsg : string );
var s : TStringStream;
s := TStringStream.Create( htmlMsg );
RichView1.Clear;
RichView1.LoadHTMLFromStream( s );
RichView1.Format;
s.Free;
end;[/code]
My problem is that the HTML is showing in what appears to be Times Roman font.
Using Delphi's Object Inspector, I review what is in RVStyle1.TextStyles and see this list of TFontInfo instances: 0 - Normal text, 1 - Heading, 2 - Subheading, 3 - Keywords, 4 - Jump 1, and 5 - Jump 2
Looking into each of these TFontInfo instances, they all have FontName = 'Arial'. So I do not understand why Arial is not being used. As I said above, the HTML looks like it is using font "Times Roman".
Reading a variety of TRichView support posts, I see that the following needs to be performed, although what this code does is simply set the FontName for each style to "Arial" which is what I already see in the object inspector:
[code]procedure TFontTestForm.FontReplace(rv:TRichView);
// Ref: https://richedit.com/support/trichview. ... ment_3.htm
var i:Integer;
RVEStyle: TRVStyle;
RVEStyle := rv.Style;
for i := 0 to RVEStyle.TextStyles.Count-1 do
RVEStyle.TextStyles[i].FontName := 'Tahoma';
rv.Format;
end;[/code]
So, even after calling FontReplace(RichView1) in my FormCreate method, I am still seeing my HTML printed in Times Roman when calling renderHtml(). For example, I tried this:
[code]renderHtml( 'Hello, <b>this</b> <u>is</u> a <i>senseless</i> <font color="red">sentence</font>.');[/code]
Then I thought I needed to specify the font style ("Normal text"), so I tried this:
[code]renderHtml( '<font style="Normal text">' +
+ '</font>'
);[/code]
Please help. This should be a simple task, but I do not know what I am doing wrong.
Thank you,
- SV
svinson
Re: How to specify default font when printing HTML with TRichView v21.0
Post by svinson »
Note: in my code sample above, I temporarily tried changing the font to "Tahoma", simply to see if I could induce any changes. My original intent is to use "Arial". I just want to learn how to set the font to something OTHER than the default Times Roman font.
Default fonts for HTML are specified in the global singleton object RVDefaultLoadProperties (RVDefReadProps unit).
Specifically, this object has properties: DefaultFontName, DefaultMonoSpacedFontName.
svinson
Post by svinson »
Based on your response, I searched your source code to see RVDefReadProps.pas in the TRichView\Source folder. Looking in that unit, I see the setter property DefaultFontName. With the parent class being the singleton that you mentioned, I see in the Initialization section of that unit the code instantiates RVDefaultLoadProperties. So far, so good.
So, I added RVDefReadProps to my USES list. Then in my FormCreate method, I added this line:
RVDefaultLoadProperties.DefaultFontName := 'Arial';
Unfortunately, the HTML text in my RichView1 panel has not changed. It is still being shown in what looks like Times-Roman font.
There are other setters in that class -- one for mono font as you mentioned, another for bulletizing, etc. etc. I only made use of DefaultFontName -- do I need to set anything else?
Sorry if I'm missing something else. Let me know.
Thanks,
Steve
This is a bug, sorry.
A fix is modifying RVHTMLTypes.pas. Change TRVHTMLStylesInfo.SetFontFamiliesDef to:
procedure TRVHTMLStylesInfo.SetFontFamiliesDef;
  FFontFamilies.Clear;
Here is my test:
procedure AddHTML(rv: TCustomRichView; const S: UnicodeString);
  Stream: TMemoryStream;
  S2: UTF8String;
  S2 := UTF8Encode(S);
  Stream.WriteBuffer(PAnsiChar(S2)^, Length(S2));
  Stream.Position := 0;
  rv.LoadHTMLFromStream(Stream, '', CP_UTF8);
  Stream.Free;
procedure TForm3.ToolButton12Click(Sender: TObject);
  RichViewEdit1.Clear;
  RichViewEdit1.StyleTemplateInsertMode := rvstimUseSourceFormatting;
  AddHTML(RichViewEdit1, 'Hello <b>world</b>!');
  RVDefaultLoadProperties.DefaultFontName := 'Times New Roman';
  RVDefaultLoadProperties.DefaultFontName := 'Comic Sans MS';
  RichViewEdit1.Format;
Please note that I assigned RichViewEdit1.StyleTemplateInsertMode := rvstimUseSourceFormatting.
With the default value, if RichViewEdit1.UseStyleTemplates = True, TRichView converts HTML formatting to the formatting specified in its StyleTemplates (it happens when loading HTML in non-empty editor; TRichView considers it as an insertion and applies StyleTemplateInsertMode).
svinson
Post by svinson »
That was the fix! Thank you.
