About RAD Studio 11.3 compatibility
RAD Studio 11.3 is completely compatible with RAD Studio 11, 11.1, and 11.2.
You can use the existing version of TRichView and RVMedia (both the trial and the full version), no changes in the components or installers are required.
Update: it is appeared that RAD Studio 11.3 has changes that affect compatibility of precompiled units. As a result, the trial versions of our components, compiled in RAD Studio 11.3, cannot be installed in older version of RAD Studio 11.x. Please upgrade your version of RAD Studio if you want to install trial versions of our components. This problem does not affect the full version, because it includes source code.
