Greetings,
Is there an equivalent to this function that appears changed?
I was used rvActionSave.FileTitle to update a status. Is there a way to get the file name another way?
Richview 21 rvActionSave.FileTitle
Re: Richview 21 rvActionSave.FileTitle
I see it is meant to be used with RvHTMLViewImporter
which I was using it for just getting the FileName. So I was using it improperly.
This property was used to add <title> to saved HTML files.
In the new version, DocParameters.Title of the target editor is used.
A file name is not assigned to this property.
Thanks, sorry I didn't put this post in Support
