RVOleDropEffect
[email protected]
RVOleDropEffect
Post by [email protected] »
I have a problem with Drag&Drop, in OleDragOver I want to set the DropEffect to rvdeLink, but rvdeLink is defined differently than DROPEFFECT_LINK (oleidl.h). Is there a reasone for this?
Also the Mouse Cursor does not change, like it does in e.g. Explorer.
You are right, this is a bug, and the reason is really in rvdeLink<>DROPEFFECT_LINK.
Fix:
in RVEdit.pas, add the function:
function ConvertDropEffect(Effect: TRVOleDropEffect): Integer;
  Result := ord(Effect);
  if Result=3 then
    inc(Result);
In the same unit, change 2 calls of ord(AEffect) to ConvertDropEffect(AEffect).
