Hi There,
Wondering if someone would be able to provide some assistance with an issue we are seeing with some documents coming out of TRichView. We are finding some documents are unable to be converted from RTF to PDF, the same documents cannot be opened in WordPad (open as a blank document), but can be opened in Word.
I have created a simple document with a table and a text string that reproduces the issue (please see attached RVF and the resultant RTF).
RTF and Resultant PDF unreadable
- test_textbox.rtf
- (2.62 KiB) Downloaded 876 times
- test_textbox.rvf
- (14.26 KiB) Downloaded 894 times
Re: RTF and Resultant PDF unreadable
As I can see, this document is loaded in TRichView without problems.
How do you save PDF?
