EM_FORMATRANGE inside of RichViewEdit?
Loesterinfo
Post by Loesterinfo »
Hello Serguey
What is equivalent to EM_FORMATRANGE of RichEdit in RichViewEdit?
Thankful.
TRVReportHelper component
Demos:
Demo\Delphi\Assorted\Graphics\ToImage\ - drawing to metafile
Demo\Delphi\Assorted\Printing\ReportHelper\ - drawing on printer canvas
Loesterinfo
RE - TRVReportHelper component
The one that I need is to print exactly in the way that is in TRichViewEdit. With a certain size, type largura=9 .4 cm.
thankful.
Sorry, TRichView does not support WYSIWYG editing.
You can display pages on screen how they will be printed:
- using TRVPrint+TRVPrintPreview
- using TRVReportHelper, see the demo http://www.trichview.com/forums/viewtopic.php?t=65
But it is a displaying, not editing. You can set the document width (MinTextWidth and MaxTextWidth properties) to the same width as it will be printed (with the correction according to the difference in resolutions), but it will give only approximate results.
