[Demo] Replacing controls with text
controls2text.zip
(3.6 KiB) Downloaded 1944 times
Shows how to change controls to their text value
[+] History of updates
2008-Dec-11: for compatibility with TRichView 11 and Delphi 2009.
2011-Oct-1: for compatibility with TRichView 13.4
2018-Apr-9: for compatibility with TRichView 17.3
[+] Old versions
http://www.trichview.com/support/files/ ... s2text.zip - for TRichView 13.4-17.2
Last edited by Sergey Tkachenko on Sat Oct 01, 2011 9:18 am, edited 2 times in total.
Similar code can be used to change controls to images.
In this code, GetControlGraphic is your function returning graphic representation of the given control. You can use DrawControl function from CtrlImg unit, but it is not able to create images for all types of controls.
{ Inserting graphic item in RVData at the ItemNo position }
{ some undocumented functions are used }
procedure InsertGraphicItem(RVData: TCustomRVData; ItemNo: Integer;
  ItemName: TRVRawByteString; gr: TGraphic; VAlign: TRVVAlign;
  PageBreak, NewLine, NewPara: Boolean);
var Item: TRVGraphicItemInfo;
  Item := TRVGraphicItemInfo.CreateEx(RVData, gr, VAlign);
  Item.SameAsPrev := not NewPara;
  if NewLine and not NewPara then
    Item.BR := True;
  if PageBreak then
    Item.PageBreakBefore := True;
  Item.Inserting(RVData, ItemName, False);
  RVData.Items.InsertObject(ItemNo, ItemName, Item);
  Item.Inserted(RVData, ItemNo);
{ Changes all controls in RVData (and its sub-data) to their graphic
  representations }
procedure ControlsToGraphics(RVData: TCustomRVData);
var i,r,c: Integer;
    Control: TControl;
    ControlName: TRVAnsiString;
    ControlTag: TRVTag;
    ControlVAlign: TRVVAlign;
    table: TRVTableItemInfo;
    PageBreak, NewLine, NewPara: Boolean;
    Graphic: TBitmap;
    case RVData.GetItemStyle(i) of
      rvsTable:
              if table.Cells[r,c]<>nil then
                ControlsToGraphics(table.Cells[r,c].GetRVData);
      rvsComponent:
          RVData.GetControlInfo(i, ControlName, Control, ControlVAlign, ControlTag);
          Graphic := GetControlGraphic(Control);
          PageBreak := RVData.PageBreaksBeforeItems[i];
          NewLine := RVData.IsFromNewLine(i);
          NewPara := RVData.IsParaStart(i);
          RVData.DeleteItems(i, 1);
          // you can copy tag as well
          InsertGraphicItem(RVData, i, ControlName, Graphic, ControlVAlign,
            PageBreak, NewLine, NewPara);
Updates
