I dont believe this is possible. However, I wish to confirm prior to investigating other options.
I am trying to take a local rtsp source (rtsp://some-local-host:8554/abc) and stream it to a remote rtsp server (specifically rtsp-simple-server). The reason is to allow remote viewing of local streams that are generally behind a customer firewall (I dont have access to customer firewalls, or more correctly I dont wish to configure all of my customers' differing firewalls). I belive the TCAMSender component uses a proprietary protocol and thus isnt able to accomplish this task. Correct? Any thoughts on this problem would be appreciated.
[Local deployment is windows, Remote deployment is Unix]
Thank you
Sending as RTSP Stream?
Re: Sending as RTSP Stream?
Unfortunately, you are right.
TRVCamSender can send data only to TRVCamReceiver, in a proprietary format.
There is a chance that TRVCamRecorder can be used to send RTSP streams, but it is not tested, so I cannot guarantee. This component can use FFmpeg to record files. But it looks like FFmpeg output can be used to send RTSP instead of just creating a local file. Maybe you can set RVCamRecorder.OutputFileName to the value that can be accepted as a source by rtsp-simple-server...
Thank you. I appreciate your response. Cheers
