SaveHTML place images in images folder
standay
Post by standay »
I'm using this and it works fine:
      memo.SaveHTML(FileSaveDialog1.FileName,
        ExtractFileName(FileSaveDialog1.FileName), 'img',[ rvsoUTF8] );
That's great, but I want the images in a subfolder relative to the html file itself. I've looked at SaveImage2 but can't figure out how to do this. It's probably very simple but I can't get it to work! If it involves using SaveImage2, can you post how I would call it and from where?
Thanks Sergey
Re: SaveHTML place images in images folder
ImagesPrefix parameter may include path, such as 'images\img'.
This folder must exist (create it before saving HTML).
After saving, I suggest calling RemoveDir() for this folder, it will remove it only if it is empty.
As a sample, you can see RichViewActions code (search for calls of SaveHTML in RichViewActions.pas).
standay
Post by standay »
Thanks Sergey. I was hoping it was something as simple as that, it works great. I switched from SaveHTML to SaveHTMLEX as it works better. SaveHTML did not export paragraphs with background colors which is something I use frequently.
