Saving document with footnote/endnote as XML will cause error
edwinyzh
Post by edwinyzh »
I'm using the latest version of RichView.
Saving document with footnote/endnote as XML will cause error.
Steps to reproduce:
- Open 'RichViewActions\Demos\DelphiUnicode\ActionTest'
- Add a TRichViewXml (component property values are as following).
- Compile and run, goto Insert -> Insert FootNote (or EndNote), now save the document as xml (code below).
- Error will now happen.
TRichViewXml properties:
  XMLStore: TRichViewXML;
  XMLStore := TRichViewXML.Create(Self);
  XMLStore.DefaultBreakColor := clNone;
  XMLStore.DefaultBreakWidth := 1;
  XMLStore.DefaultParaNo := 0;
  XMLStore.DefaultStyleNo := 0;
  XMLStore.DefaultVAlign := rvvaBaseline;
  XMLStore.Encoding := 'UTF-8';
  XMLStore.InsLoadBackground := False;
  XMLStore.InsLoadPrint := False;
  XMLStore.InsStyleLoadingMode := slmMerge;
  XMLStore.LoadBackground := False;
  XMLStore.LoadPrint := False;
  XMLStore.LoadTagMode := True;
  XMLStore.RichView := RichViewEdit1;
  XMLStore.RootElement := 'rvxml';
  XMLStore.SaveBackground := True;
  XMLStore.SaveImgToFiles := False;
  XMLStore.SavePrint := False;
  XMLStore.SaveSelectionBackground := True;
  XMLStore.SaveSelectionImgToFiles := False;
  XMLStore.SaveSelectionPrint := False;
  XMLStore.SaveSelectionStyles := True;
  XMLStore.SaveLineBreaks := True;
  XMLStore.SaveStyleNames := True;
  XMLStore.SaveStyles := False;
  XMLStore.StyleLoadingMode := slmMerge;
  XMLStore.UseStyleNames := False;
  XMLStore.WantTabs := False;
Code to save as xml:
procedure TForm3.Saveasxml1Click(Sender: TObject);
  fn: string;
  fn := ExtractFilePath(Application.ExeName) + 'text.xml';
  XMLStore.SaveToFile(fn);
Call stack produced by madExcept for 'saving footnote error':
exception class    : EListError
exception message  : List index out of bounds (-1).
main thread ($1dd4):
0051e18d +015 ActionTestUni.exe System.Classes          TList.Get
006cac4a +00a ActionTestUni.exe DLines          797  +1 TRVDrawLines.Get
00877ac8 +11c ActionTestUni.exe CRVFData       5730 +46 TCustomRVFormattedData.Item2DrawItem
00bdbb0b +103 ActionTestUni.exe RVXMLRoutines  2927 +18 WriteText
00be0ca1 +045 ActionTestUni.exe RVXMLRoutines  4073  +3 AddText
00be10a3 +3df ActionTestUni.exe RVXMLRoutines  4169 +90 SaveRVDataToXML
00bdcc34 +0a0 ActionTestUni.exe RVXMLRoutines  3144  +3 WriteNoteProps
00bdcc60 +008 ActionTestUni.exe RVXMLRoutines  3153  +1 WriteFootnote
00be09f4 +330 ActionTestUni.exe RVXMLRoutines  4034 +84 AddNonTextItem
00be0fc5 +301 ActionTestUni.exe RVXMLRoutines  4154 +75 SaveRVDataToXML
00beecb8 +36c ActionTestUni.exe RVXMLRoutines  7702 +75 RVSaveToXML
00bf11fa +112 ActionTestUni.exe RichViewXML     554 +19 TRichViewXML.SaveToXML
00bf10a6 +062 ActionTestUni.exe RichViewXML     526  +4 TRichViewXML.SaveToStream
00bf0ffa +066 ActionTestUni.exe RichViewXML     513  +4 TRichViewXML.SaveToFile
00bf89b8 +054 ActionTestUni.exe Unit3Unicode    935  +2 TForm3.Saveasxml1Click
madExcept-produced call stack for the endnote saving error:
exception class    : EAccessViolation
exception message  : Access violation at address 0051E17E in module 'ActionTestUni.exe'. Read of address 00000008.
main thread ($30b8):
0051e17e +006 ActionTestUni.exe System.Classes          TList.Get
00bdcc74 +008 ActionTestUni.exe RVXMLRoutines  3158  +1 WriteEndnote
00be0a1c +358 ActionTestUni.exe RVXMLRoutines  4039 +89 AddNonTextItem
Re: Saving document with footnote/endnote as XML will cause error
Assign SaveLineBreaks property = False.
I'll fix it in the next update.
Actually, this property is not too useful: it saves line breaks in places where text wraps. These line breaks cannot be loaded.
This option does not affect saving true line breaks, they are always saved and loaded.
edwinyzh
Post by edwinyzh »
Sergey Tkachenko wrote: Tue Jul 12, 2022 5:53 pm Assign SaveLineBreaks property = False.
I tried, it seems fixed the issue now. Thanks!
