With TRichViewXml can I intercept the saving and loading of image files?
edwinyzh
Post by edwinyzh »
The idea is not to save the images to the xml file but provides an event which allows me to save the images to anywhere. Same applies to loading of the images.
The idea is to avoid duplicated images being saved.
Thanks.
edwinyzh
Re: With TRichViewXml can I intercept the saving and loading of image files?
Post by edwinyzh »
Maybe `TCustomRichView.OnRVFPictureNeeded` is what I need? Does the event works when saving to/loading from xml?
Thanks.
In the current version, TRichViewXML does not call any events in this case.
In the next update, OnSaveImage2 and OnImportPicture will be used.
edwinyzh
Post by edwinyzh »
Sergey Tkachenko wrote: Wed Jun 22, 2022 2:15 pm In the current version, TRichViewXML does not call any events in this case.
Great!
