Is TRVHunSpell thread-safe and can be used for multiple editors?
edwinyzh
Post by edwinyzh »
Can one TRVHunSpell object (alone with a TRVAHunSpellInterface) be used by multiple editors for live spell check? As we know, the OnSpellingCheck event is called in a background thread.
edwinyzh
Re: Is TRVHunSpell thread-safe and can be used for multiple editors?
Post by edwinyzh »
According to the RichViewAtions document:
Create TRVAHunSpellInterface component, assign it to SpellInterface property of TRVAControlPanel component.
Create TRVHunSpell component, assign it to HunSpell property of this TRVAHunSpellInterface component.
Currently I have only a single TRVAControlPanel but have multiple editors. By looking at the TRichViewEdit source code, I found that each editor has its own spell check thread. Does it mean with the approach above, there will be multiple threads accessing the same TRVAHunSpellInterface/TRVHunSpell pair?
Yes, there will be one thread for each editor.
So I recommend to protect OnSpellingCheck code by a TCriticalSection.
edwinyzh
Post by edwinyzh »
Great, it's a piece of cake!
