I have trouble with Page Break action. When I apply it, text lines are wrapped on each next page(s), see screenshot.
Strange, but there is no effect when I checked "Keep lines together" and "Keep with next".
I'm using Style Templates in SRichViewEdit.
Please help)
Text lines are wrapped on separate pages (Page Break Action)
- 2022-05-14_181449.png (66.1 KiB) Viewed 15278 times
Re: Text lines are wrapped on separate pages (Page Break Action)
Do you mean that if you apply this action one time, it adds many page breaks?
Yes. I typed a long paragraph of text in a few lines. Then I set cursor to the start position and press the button with TrvActionInsertPageBreak. I do not perform any other (special) formatting actions (
Any updates on the issue?
I confirm the bug.
Quick fix: open SclRView.pas, find
change to:
ElementNotFit :=
RichViewEdit.PageBreaksBeforeItems[srvCurItem.ItemNo] or
ElementNotFit :=
((CurDrawItem.Offs <= RichViewEdit.GetOffsBeforeItem(srvCurItem.ItemNo)) and
RichViewEdit.PageBreaksBeforeItems[srvCurItem.ItemNo]) or
Fixed in the todays update (ScaleRichView 11.3)
