rvHtmlImporter style indent
jgkoehn
Post by jgkoehn »
Greetings
Is the following tag supported in the rvHtmlImporter?
<p style="text-indent: 40px">This text is indented.</p>
Mainly this portion
If not, or in another way is there a better place to look for more info on rvHtmlImporter?
Re: rvHtmlImporter style indent
TrvHtmlImporter does not support CSS in HTML (except for a very limited set of CSS attributes).
For HTML containing CSS formatting, use TrvHtmlViewImporter instead. However, it is available only for VCL version of TRichView.
TrvHtmlViewImporter requires a free third-party component THTMLViewer https://github.com/BerndGabriel/HtmlViewer.
Plans for future:
I do not plan to improve THtmlImporter. Instead, I plan to implement TRichView.LoadHtml method from scratch. I plan to implement it in this year, but I cannot guarantee it.
jgkoehn
Post by jgkoehn »
Greetings Sergey,
Ah thank you so much for the information.
I understand there is so much in html to look into and a native would be better.
I personally have gone and duplicated HtmlImporter and modified it a lot to support our needs for special import. (It also has a regex engine so we can change tags on the fly before hand.)
Thank you again for your excellent help. I'll look into the other code. Thanks again.
jgkoehn
Post by jgkoehn »
Greetings Sergey,
I added a bit to rvHtmlViewImport (I think you said though it will no longer be supported, correct?)
If it is easy to add perhaps update this:
function TRVHTMLViewImporter.AppendFromFile(const FileName: TRVUnicodeString;
  RV: TCustomRichView): Boolean;
  Result := HTMLViewer <> nil;
  if not Result then
    HTMLViewer.LoadFromFile(FileName);
    AppendHtmlViewer(HTMLViewer, RV, ExtractFilePath(FileName));
  except
    Result := False;
This makes it possible to Append or could change it to fix Insert well sort of. Just a quick idea.
Ok, I'll add this method in the next update.
