Scalerichviewedit Web Layout client document height
tomr
Post by tomr »
Hello Richview Support,
I have a question regarding the Scalerichview component. If the web layout is selected there is only one page for the document. The document height is scaling automatically with the text inside from the Scalerichview.
Beispiel1 Kleiner Text.png (54.24 KiB) Viewed 8283 times
Beispiel2 mittlerer Text.png (86.33 KiB) Viewed 8283 times
Is there a way to set the document height manually? For example to the bottom of the window.
Best regards
Tom
Re: Scalerichviewedit Web Layout client document height
"Read-mode" is close to what you want: like in "web mode", page width = window width; like in "web mode", scaling zooms content instead of zooming pages; but page height is equal to window height. But if content does not fit the window, it is separated into multiple pages (scrolled horizontally)
tomr
Post by tomr »
Thank you for your fast reply.
You are right, it comes close to what I want, but is there a possibility that it will not be separated into multiple pages?
